Can I mirror Surface-Knit?
Can I mirror the face I have shown in the pic?
First I deleted small surfaces created by using more than one fillet, then Surface-Filled the surface and finally knitted and formed the solid again. I can do the same for the opposite spot but I wonder if I could save time by using mirror, I myself failed to do it..however I'm newbie with surfaces.
Comments 4
You will struggle to mirror features when using surfaces. If you mirror the surface once you have created it, you should have less problems. I've uploaded a file with this surface mirrored- you just needed to mirror the surface body before you performed the knit.
yes, just select bodies instead of features or faces while mirroeing.
