CAN I USE SOLID WORKS FOR DRAFTING DETAILED ENGINEERING DRAWINGS OF PRESSURE VESSEL?
I WANTS TO USE SOLID WORKS FOR CHEMICAL PROCESS EQUIPMENT SUCH AS
[Reactors, Heat Exchangers, Pressure Vessels, Autoclaves, Tanks, Rotary Dryers, Distillation Columns, Storage tanks, Rotary Vacuum Dryer, Flakers, Pressure Filter, Wiped Film Evaporator, Falling Film Evaporators]
Yes.
Do a search in the library for all of the parts you mentioned: https://grabcad.com/library?page=1&time=all_time&sort=recent&query=heat%20exchanger
Many are shown.
Many are built in SOLIDWORKS.
Many do not have 2D drawings, but there is no reason a drawing can't be made of the parts and assemblies.
thank for your Answer. when i make this drawings. I upload for others.
