Can someone convert DXF file into SAT/IGES Format
Hi,
please someone convert DXF file into SAT/IGES fomat.
I would be very thankful for the support and cooperation. please attached find the file with this email.
cheers
varun
No solid data is present, and the DXF can't be extruded, I'm not sure if you'll be able to open the SAT file.
thank you very much for your effort, but there is error not able to open the file. Actually i want to open this file in abaqus
Comments 2
Varun,
Try this sample part. It is a simple extrusion with a bunch of holes in it. There are ~40 holes/pores per inch.
fred,
i really appreciate for the help. I need to make something like in the photo. please see the photo attached with this message
Try this model, it is a cube with a bunch of spheres removed from it. There are many variations or sphere placement, size and spacing, so this is best used as a sample.
I'm not sure why it would import as a cube and sphere. The model is a cube with a bunch of spheres removed from it. I've attached an image.
check www,3dprintingco,co,nz john knows aloth about file conversion of many kind, Good Luck
