Can someone figure out why the cutout won't close in Solid Edge?
Trying to make a solid corvette but I've already put too much time into what little I have done I don't want to lose it. If you figure it out can you fix it and upload the fixed as a solidedge part file? Much appreciated, thank you.
Comments 2
Pretty sure I know why...but can anyone else figure it out???
Please check weather you are working in "ordered mode" or "Synchronus mode". If you are working in Ordered mode, remove the sketch you made for cutout or remove the cutout from the path finder. If you are working in Sychoronus mode adjust the live rules to remove the cut out. Pleas feel free to post still if you find problem
