can someone please give me drawings for a Drywall Lifter ?
i need the drawings for my class project. i only have two days left to submit the drawings. i would really appreciate the help and i dont mind paying.
Comments 2
I need 3D cad designs for inventor and in standard mm units.
Feature and Specification:
Max Loading Capacity: 150lb /68kg
Min Loading Height: 4 ft/1220mm
Max Loading Height: 11 ft/3350mm
Drywall Panel/ Sheet size capacity: 4ft x 16ft (1220mm x 4880mm)
Heavy duty Frame Base and Center Legs stand up to heavy use
Easy to Assemble & Disassemble- No Tools Required
5"Rubber caster wheels with brake
Fast action single stage winch with silent cam lock brake
High tensile 1/8” aircraft cable
Package Size: 1300 x 50 x 170mm
Weight: 40/43kg
