Can someone who has AutoDesk please help? I need a file converstion
I need this .ipt file converted to either a .STEP file or .IGES file so I can open it in SOLIDWORKS.
Thank you!
Dear Christian,
If you click the 'I" icon in the top left corner and go on the drop-down menu, select "Export". Then click "CAD Format". When the window pops up, under the file name in the window, it should show "Save as type:". Click on the bar next to that and select the desired format. Click save, and there you have it! You successfully converted a file!
