Cant create proper standard hole in creo 2.0
i have tried to create a standard hole with thread M 48*5 but the hole diameter is not updating and can increase a max diameter of 2.44mm for thread of M68* 6 . I am frustrated what might be the reason. I am using creo 2.0 in windows 8.1.Can anyone please help me solve the problem
The error shown at the bottom of graphics window is "Standard hole thread diam dim_id d7 is not in accordance with hole table."
u can use extrude 1.draw a object on the source object then 2.extrude it and try the icon remove on the top left side of the ribbon
