Catia:Half Dimension Default Setting
When I give dimension between two two lines it always shows double of actual value. ex.. If distance is 2mm it shows as 4mm. One way I know is right click then half-dimension. But doing this every time and checking if every value is very difficult. Can anyone suggest me a way out to turn off this thing.
Thank You
Once you click half-dimension (to close it), it wont measure double. Next measurement will be exact dimension.
