CATIA runtime exception "CLICK OK TO TERMINATE"
I have installed catia v5 r21 in my pc and when i launch catia a window opens saying click ok to terminate.
Earlier I have installed catia but it didnt cause any of these problems. please can any one help me
This happens to me sometimes. Also not sure what might be reason. But bad when you don't save file while working.
Since this happens as soon as you start CATIA, there must be something wrong with the installation. Are you using the recommended hardware and graphics? You could try re-installing CATIA, but I recommend talking to your CATIA reseller and get them to help you.
Hi, friends I tried everything but it didn't worked so I reinstalled my windows.And the problem was solved.I have done it because I once downloaded several unwanted,nontrustable published software and to run them I deleted some winidows files.I that might caused this problem.Take a look at this image
