Catia sketch Tracer Issues
By shiva kumar on 13 Jun 16:34 6 answers 0 comments
When i import an image in Catia V5 R20 sketch tracer, when it is in conical view the image is visible, but when i switch it to cylindrical view the image gets vanished
Added images
Square Square
  • DIPESH PAWAR
    DIPESH PAWAR over 2 years ago
    change the setting into material>general.
  • shiva kumar
    shiva kumar over 2 years ago
    "change the setting into material>general" means are you talking about View mode settings??? I didn't get that. Can you please tell again . Thank you.
  • aakash
    aakash over 2 years ago
    i am also facing the same problem , pls someone help us out
  • shiva kumar
    Is there any other Forums like this? i want to post this question in as many forums as possible
  • DIPESH PAWAR
    then change the view, for example front view,top view as per your requirement
  • shiva kumar
    Yea. i tried even that. not worked
Add your answer to: "Catia sketch Tracer Issues"
