Catia v5 - coordinate box
Hi, how do you get to coordinate/measurements box when doing constraints in sketch?
You don't. There is no coordinate constraint capability within a CATIA sketch. Instead, add a horizontal distance constraint and a vertical distance constraint.
Or you can exit the sketch, and Measure the point/vertex to get the coordinates and Keep the measure.
Or you can add a coordinate dimension to a drawing.
