Convert complex sketche sinto one contious spline
Heres a problem I often encounter in soldiworks. How can I combine a series of sketches into one nice simple not too heavy spline? I will use the fit spline tool but the surface quality that is created is not that good since the spline is so heavy. So how can I create a simpler contentious spline. As you can see in picture I have a series of half circles how can I make one spline that will give decent surface
Start a new sketch. Use the 'Convert Entities' tool and select all the elements of the other sketches.
