Convert DWG to STEP or IPT format
Hello all,
Please would you help to convert this DWG to STEP or INV. (2010)
Thank you so much!
* may something problem as i can not attached file here!_@3.7MB)
Phil
Tutorial......
Answered with a tutorial: https://grabcad.com/tutorials/convert-dwg-to-step-or-ipt-format
Try "STEPOUT" command.
This works only if you are using higher version Auto-cad.!!
Yes right!
Bro here i m giving you all conversion types (autocad,catia,nx.....step,iges dwg,dxf)
https://youtu.be/pckHdjzRVrg
https://youtu.be/B7ptS8E8TeM
https://youtu.be/aIuZAOLY2n4
https://youtu.be/5S1ftkMJL30
https://youtu.be/BM6orCmUdPQ
https://youtu.be/Wmgzm8JhKpc
..............................................................it's my channel
