could any one knows how to convert the polymeshes into solids in autocad 2013
tried lot for converting the polymeshes to solid but no use.
if it is all connected but won't convert to solid then if there are opening close them with the patch command then select the whole item and use the sculpt command to convert to solid...i have had this a few times with tank roofs that have collapsed so then i get a polymesh and they want me to convert it to a solid
