could anyone explain me about make flexible option in Pro E assembly ??
i need some good examples if you can?
Flexibility option in proe is mostly used for modelling components such as diaphragm rubber seals,springs free state components.Go to assembly.select any component ,just right click over the components and chose make flexible,now choose the dimensions ,features parameters u have to change.remember components changed will reflect only in assembly mode there wont be any change in the original part component
Use this tutorial if you dont understand the written help.i hope this will clear your concept.
http://www.youtube.com/watch?v=I1nzWS_K_zU
