Design of an Ocean Turbine Blade in Pro/E
I want a blade to be designed in Pro/E
File is attached regarding Dimensions of blade
You may design the same using extrude and sketch options in Pro/E wildfifd 2.0
You may go through the sketching options and modelling tools such as exrude, revolve , blend etc.
The optimum way to design this blade, based on your sketch, would be tu use a general blend with smooth transitions between sections. A series of extrudes would give very disjoint geometry.
Regards,
Tom P
Click
Insert>Blend>Protrusion>Parallel>Regular>Sketch Sec> Done
Choose Attributes>Smooth> Done
Sketch section 1 to up to section 9
Set depth for sections.
Finally click OK to construct feature.
Hi Jinto,
I try to make the design using blend,
But according your dimension, the curve not really smooth.
How about yours?
I need that design. First and Final should be as per Dimensions attached.
can any one send me step by step tutorial to design above turbine blade in ProE...Thanks
I need this file attached in Pro/E v 4.0
Thanks in anticipation
I need file attached to be designed in ProE
Thanks in Anticipation
