Design of an Ocean Turbine Blade in Pro/E
I want to have a Pro/E Deisgn of the following attached file
Hi. I've no experience in making turbine blade. so I dont know exactly what critical specification that I have to care about the design.
may be my modeling will help you.
You can edit according to your specific design and dimension
More photos and details of the size... thank you.I want to try with your details
Thanks Alot
Thank You very much. I'll edit the parameters.. thanks
Now the model of ocean blade turbine in step format uploaded to library.
ocean turbine blade
Surface is smooth enough.
I already uploaded the Ocean Turbine Blade in Pro/E format, so now you can download it.
