Differential Question
By Andi Hoxhaj on 26 Aug 15:51 1 answer 0 comments
Im trying to build this gearbox. I had a question about the plastic plates that go after the gears.Which gears are supposed to lock in and which ones rotate?
Added images
Square
1 answer
  • saeid mirshahidi
    saeid mirshahidi about 3 years ago
    if you ask about part No. 78461, This part is only for lubrication & Don't engaged to gear. The gear engaged to output shaft No. 87470
Add your answer to: "Differential Question"
