dimensions not same as required for my assembly
I am using ProE. I am assembling some components i made. i downloaded a screw from grabcad and when i am going to assemble the screw. the screw appears to be very small comparatively with the rest assembly. i required an M3x6 screw. my assembly part are of the right dimensions. was wondering if i could scale the screw size. or like measure the sizes.
Bit sure, you have made assembly parts in inlbs_scale.
try to change unit to mmns_ from model properties!
