Does anyone know how to make a cylinder with cutouts and radii in solidworks 2014?
Does anyone know how to make a cylinder with cutouts and radii in solidworks?
The cylinder has radius corners and a pattern cut out of one of the edges.
I've tried the unfold feature but can't seem to fillet the corners and make changes to the edges. I've attached the flat pattern version dxf only. Probably a simple question for someone.
Hi james,
The easiest way is to use the wrap feature, see link to youtube Video https://www.youtube.com/watch?v=t9wTZrV-GL4
john
Hi James,
Had a look at this and came up with this example.
john
you could have used the fillet command to add the radii at the corners
Hi James,
Attached file, just roll back the history tree, that the blue bar at the bottom of the feature tree to see how I did this.
rdgs
John
hi james
file didnt seem to have been attached
Hi James,
I tried the fillet command on your file and it works OK, see attached.
john
Answered with a tutorial: https://grabcad.com/tutorials/does-anyone-know-how-to-make-a-cylinder-with-cutouts-and-radii-in-solidworks-2014--2
just select the corner edge, email me your model and I will take a look.
john
Hi John
Thanks for your help with this fillet thing. Your example is what I had managed to achieve using the unfold feature but I still couldn't get the fillet to be applied. I managed to get a result which probably could have been done in a better way.
I've attached your file with a modification. I did this with the extrude cut after doing a sketch. Probably not the right way.
PS I like the wrap feature you showed me.
regards
James (Australia)
Thanks John. I tried that but it wouldn't let me do it so I thought I'd extrude cut the pieces I didn't want. Long way round I think.
I'll send you the result soon. Took me a long time but I'm still learning.
regards
James
Did you do that with the wrap feature? I did mine starting with an arc first on the sheet metal tab then used the unfold feature. I tried using the fillet command on the feature menu but didn't work. Must be doing something wrong.
Hi John
Here is the file I worked on. Pretty basic stuff compared to your projects.
I just had a look. Amazing models..
regards
James
Hi John
Hmmm. I tried again but still no luck. I made an arc first, then unfold, then fillet edge (constant) but always says unable to make fillet. Not sure now. Thanks for your help though. Checked your snapshot and selected thse edges. Maybe I'm selecting the wrong edges? As far as I can see, all looks okay but obviously missing something.
regards
James
Hi John
Did you receive my email address? Would be interested in seeing the video you made with the fillets..
regards
James
I didn't get it. You left the "r" out of the address.
It is jamesr62@gmail.com
Hi, after i take a look on your dxf file, i just guest that you are trying to add fillet to a sheet metal, but in form of cylinder. please take a look at my file, maybe it can help you, i add the fillet after i use unfold features first, then i use extrude cut. Not using wrapping features. Also need to consider before extrude the cylinder is a miter gap on the sketch, make sure there is gap around 0.3mm, then extrude sheet metal can be use. Don't hesitate to download the file. Anyway, i'm using 2012 version, so i can't open newer version, or you can uload iges so i can check for you. Thanks,
Comments 4
