Doesn't anyone going to help me in this site( fold according to the drawing ) http://grabcad.com/questions/please-help--2
This is a bit over the top Bilal to spam a Q&A's section....
Would it not be better to go find the answer your self and if you fail after you can not find the answer then ask in GrabCAD :P
http://wikihelp.autodesk.com/Inventor/enu/2013/Help/0126-Tutorial126/0127-Inventor127/0663-Sheet_Me663
I still don't understand. you already have it in your projects.
http://grabcad.com/library/link-cartridge-metallic-belt-7-62-mm-m13
and Help is not owed but given, you should remember this next time you need help.
oh ya you defently have a problem. I don't know if its a cause of your residense or you are just another spamming jerk. If you did this job once then why cant you do it again with differant dimensions? or did someone else do the model? I tried to be nice by dirrect messaging you but that attitude seams to get in your way. good luck getting help.
Hi Bilal
Who has the model constructed "Metallic Belt 7.62 mm M13". What is your problem?
m.gebhard
Look carefully, this 12.7-mm
Hi Bilal
I agree fully with the answer from JEFF. Also, I would set this straight as an engineer because of the credibility.
One more thing. I think be able to read and understand drawings. That still on look carfully.
good luck
m.gebhard
drawing a very frustrating
