Draw Object (inches) in drawing with metric unit
Hi.
Suppose there is a layout of room created in autocad 2007 with units in "meters".
Now if i have to draw a table in room that have a dimention of (3ft 2inch X 6ft 5inches),
please explain step by step how to draw this table.
NOTE: method without using SCALE command will be appreciated.
Hello. use align command. you will just align it onto something ( e.g. a line that is your prefered measurement) and it will take its measurement pretty much like scaling also. But i do prefer the scale command.
Like us on Facebook:
@https://www.facebook.com/metapexofficial/
Subscribe to my channel: @https://youtube.com/riopaildelan
Use a calculator and convert or draw then scale is the only way. AutoCad is not like solid modelling you have to draw to scale and the different units within dims are only calculations.
Comments 2
