drawing confused please help
Thank you for the links but I am afraid that I cannot see that detail for the path of the triangle cut out. I hope you understand what I mean ;)
So, here is my model I think the approximation is really good and as you, suppose to know better in what you are looking for, I can leave this with you to complete.
I would like though to here some comments (Hopefully good... ;)) if you found this helpful...
I know this is not the complete solution on your problem but I think it covers the 90% according to your drawing...
Regards
thats a tool bit, similar to one of these PASTILHA DE ROSCA ISCAR ( THREAD INSERT)
here's another one Solid carbid insert
hope it helps
Hi Bilal
Can you give please some more details on what exactly looking as an answer??
It will help the rest of us to understand better and give a boost on what are you doing...
In case that you are looking for someone to model this component based on this drawing you are in the wrong section of this site. But, don't worry as it happens all the time. You should consider the Request section as more appropriate)
Nuno send some good links to get a better idea on how to approach this drawing...and not the actual model of it. Good job Nuno
If you can upload the a dwg format you will find many people around to challenge... including me if you cannot share this as a public document I can send you my mail...
Let's give a try... ;)
Hi Bilal
I hope you are fine...
I was looking your drawing and I just have this filling that is not very accurate as I cannot see some edges from the front view to the Top view...
However, I cannot say anything formal as this drawing may be a bit rough and not the actual manufacturing drawing you know BETTER!!! ;)
My goal is to be as close as possible to this drawing and so far I think I am. ;)
A quick question is about that triangle channel (Cut-out) on the front elevation.
Does it go straight to the back face or not... I am not really sure to be honest!!!
Do you thing that you can provide a picture of the actual component???
Otherwise I can upload your model in a good level with clean and fully constrained geometries to finish it.
