Failure analysis of graded unit
hello guys. I just wanted to share with you my graded unit that i've taken on this semester.
Its a broken gear i got from my last work (at rotax hellas kart division). I am gonna do a failure analysis on it. The engine was at WOT 13500rpm when the driver downshifted to 1st gear and here are the results...
I am also going to simulate this on solidworks to see where the stress is normaly going and if it broke where it should:)
You also should specify the load and where it is located
