Flatten an oval pipe with cut on angle
I have modelled a oval pipe 68 x 32 and have put an angled cut 42mm diameter through it at 70 degrees. I now want to make a flat pattern as a template for cutting. Not so hard with a round tube but I just can't seem to get a oval tube. I have tried cutting a slice through the oval to get an edge to base my sheet metal on but it does not work. Any ideas appreciated.
In sheet metal you must use loft feature and thin feature and profile of pipe must not be connected -( it must be some space between ends). then cut a pipe at desired angle and flatten.
Hi Aled, here is the joint I am trying to convert into a flat pattern, its so a paper template can be made to make the cut in the oval pipe. As I have said round is relatively easy but oval I just can't get anywhere. Even cutting it in half and trying to do on side does not work.
Thanks Tomica,
Worked straight away never thought of that, a little more fiddly than I would have expected. But the end result is what I want thanks again.
There are many examples of flattening similar surfaces from ExactFlat. Check this out:
http://www.exactflat.com/ Scroll down a little you will find the flattening video
http://www.exactflat.com/software-for-insulation-jacket-development
hope this helps
