for surface modellig , which one is best either solid works or Creo
It's a very close thing, for the core surfacing functionality there is little difference, though setting end conditions in Curve thru' Points is easier in Creo than using 3D sketches in SW.
If you have the ISDX Style feature license in Creo then it has a much broader range than SW, particularly when you combine this with the sub-div Freestyle feature as well.
Look me up if you need more in depth assistance with either, Sean
creo is better for surfacing and solidworks is better for part modelling..c these videos to learn surfacing using creo..then decide urself ..thank u
https://youtu.be/Hek9lR4qfik
https://youtu.be/lP7Ye_uw7mg
