give me the mechanism tips to do a cam actuation with spring on it. give me the notes to do that in pro-E 5.0
I don't know how to use spring on mechanism page, in pro-e 5.0
Upload a sketch or better: your proe model to explain better what you want, because I dont really understand.
First: you need the "MDO" plug-in in Creo or proEngineer to be able to use springs.
If you have that, you can check the following tutorial:
http://books.google.de/books?id=bq-KmkRFJTAC&pg=SA8-PA1&dq=LESSON+8:+CAM+AND+FOLLOWER&hl=nl&sa=X&ei=9m_eUuHOJY2BhAfd8oHACw&ved=0CC4Q6AEwAA#v=onepage&q=LESSON%208%3A%20CAM%20AND%20FOLLOWER&f=false
Get the original files for this tutorial here:
http://www.sdcpublications.com/Textbooks/Mechanism-Design-Creo-ElementsPro-5/ISBN/978-1-58503-650-9/
I got it working, see my example:
http://www.youtube.com/watch?v=i0kR9CHBcYc
good luck and peace!
