Has Autocad an equivalent tool to Inventor's Shrinkwrap command??
Hi all,
One of my colleagues is trying to convert a 3D Autocad model (assembly type made from several solid parts) to a single individual solid, just as the Shrinkwrap tool does in Inventor.
He tried making blocks and using the Union command and doesn't work well.
Any ideas??
PS.: Can't import to Inventor, The files get corrupted and parts are not in the correct position when files opens.
(Running Autocad 2013)
Has he tried using the Group command?
I use it when drawing several multifaceted parts and then assemble them.
It keeps them together, adn have found that after I group them, it's easier to create a block from that group.
I don't have AutoCAD on this computer, but I don't think you want to make the objects a block before using Union. If you have a file where they are NOT blocks, go ahead and just Union them together.
If you don't have a file where they are not blocks, you need to select all of the blocks and use the Explode command ONCE. Then you can Union them together.
