Having issues with Photoview 360
When I try and render a Solidworks model, it says photoview360.exe has stopped working. Any possible solutions?
its a common issue in solidworks, if you also have this problem then you must reinstall the solidworks from beginning means uninstall this solidworks and delete all temp files from windows and cache files & licence file from windows ,then install again after restart your computer. then hope it will work properly
OK thank you. I thought it had to do with my graphics card or RAM. But, ill take your advice
