Heal vs Join which is to be used when?
Hello, I know join can be used to join wire frame and surfaces and we have limits in the form of gap and angle values. But can I use join by increasing the attribute values. If not what happens, when I use heal, will it fill the gap. What does join cannot do that heal does. When not to use heal....?
Thanks in advance..
join has a heal function built in so there is no need to use heal after a join. but if you offset surfaces or many other surface functions sometimes some faces cannot be offset or changed and small holes can be healed using this function.
hope this helps :)
