help me draw a 95 degree angle
2 Answer
Hoi,
I think you can figure out the 95 degree angle using this example, a hexagon with a side of 40mm.
Example:
HEXAGON SIDE OF 40 .
line
enter
50,50
@40<60
@40<120
@40<180
@40<240
@40<300
c
enter
Have fun drawing.
Danny
Danny Key is spot on.
Some Explanation:
line (this is the line command)
enter (start drawing)
50,50 (Where to start the line,(you can pick with mouse also))
@ 40<60 .....Means line "at" (40=length you want) < (60=angle you want)
@distance<angle
@45<95
C= close the gap when your finished
Angles start at 3:00 oclock in Autocad and go counter clockwise.
so Angle 0 will draw a line from the point you start to the right towards 3:00
to go straight up from the previous line ending, you would go 90 degrees, etc...
Use negative numbers to go clockwise.
