Hi Everyone... I'm working on this closed mesh object in AutoCAD but can't turn it into a solid... Any suggestions? Jeff Argov 19 Mar, 2023 08:19 PM I've attached the file. Not sure how to turn this into a solid. My goal is to export to STL so I can print in 3D... Blade.dwg Accepted answer Carlos J. Veloso Answered on 19 Mar, 2023 10:48 PM See if this can work for you. Happy 3D printing! Blade STL .png Blade Stitched .png Blade STL .stl Blade Stitched .step 1 Other answer Carlos J. Veloso Answered on 20 Mar, 2023 02:47 PM If you right click the mouse on the history browser, and click on properties it will show you if it is a "watertight" body or not. And from there, at the same time, you can also save it as a Mesh. Blade.gif
