hole wizard callout on assembly drawing
I CAN GET THE CALLOUTS ON THE NORMAL VIEWS, BUT I CANT SEEM TO GET THE HOLE CALLOUTS ON SECTION VIEWS OR HIDDEN LINES. IS THERE A WAY TO GET THE CALLOUTS TO WORK?
Hello Daniel
As far as I know, you can't give hole callouts in section views. There is no use of callouts in the section view. You can clearly see the diameters, lengths and etc. Dimension them separately.
If there is such a facility, it is good actually. But so far there is no way to get the callouts work.
