how an easy way or steps to create a frame of the motorcycle ?
I'm beginer and i want an easy step to make a frame of the motorcycle. The propyl view of the frame pipe is tabular
If it was easy, everybody could do it....
You could start with a massive block, carve it out, thus ending up with the framing.
Than by using the fillet option make the tubes.
This is king of a rough way to do it but for a beginner as yourselve it will do the job.. Good luck
Comments 3
