How can I apply an image over a wall to simulate a wall graphic?
I have a file with an area that my company will have a booth at and I need to create walls of our marketing material and get a "visual" of how it will look. I've created a cube, resized it accordingly, now on one side I tried using textures, labels, and the sizing is horribly stretched. I've tried scaling it, shifting it, etc. but no luck.
Don't go for texture, in same raw you can find " Label" from that there is a + mark add label, so add your file but make sure PNG is good, then just reduce the scale of it and click and drag where you want and there are some features, and also make sure to unchecked both side
I think this will help you
Re scale your picture aspects of your wall size
