How can i assebmle camshaft with moving springs? V12 engine
i decided to assembly V 12 car engine with all kinematics. but the problem is that when i put moving springs to assebmly in camshaft and i was assembling 10 springs for example exhaust springs than tha last 2 springs i cant assemble cause solid works tells me that the assebmly is overdefined
Hi,
I want to help you but if didn't see this assemble and this error I can't...
here you are:)...first image is camshaft and on the second is camshaft hidden as you can see i put 8 springs there but tha last 4 i cant assebmle cause if i will put them to the mates like another 8 solid works tell me the assebmy is over defined
Simply delete some of mates parts will stay on their places and try again!
