How can I bend an edge flange on a curvature plane on solidworks?
I want to make an edge flange on solidworks at the mode of sheet metal but I'm not able to do it. It will be only three milimeters bend bu solidworks doesn't let me to do it. It's possible in manufacturing because Im drawing a real model's shape.
I don't want to use the extruded boss because I need to flattened shape of the sheet in order to cut them on laser.
Thank you.
It's impossible because it's plastic deform & sheet metal feature does not support this
Comments 4
