How can i block the specification tree in Catia V5R20?
Or how to change the mouse button behaviours related to zoom, rotate? I'm used with Solidworks and i want to customize Catia to have the same shortcuts.
use display setting in tool option - Tree appearance & Tree manipulation.
see attached file.
It doesn't work:( and i have another question: when i set a shortcut button for "constraints" for example, the shortcut don't work. I set the tab button to activate the constraints but when i press it, nothing happens. Somebody knows why? Please, i need help. Thank you
