How can I change my dimensions from m to mm?
I want to make a drawing of a product I made but the dimensions all are given in m but I want them in mm. I have checked the units and that is in the right setting so I don't know where the problem comes from. Can anyone help me?
Also you can change this here in part.
Or when you create skech or use features in dimension you can add m or mm:
at the bottom right corner of solidworks you will find a button "MKS"
click on it and change it to "MMSG"
