How can I change the ground plane when rendering in catia?
How can I change the ground plane when rendering in catia?Sometimes the ground plane does not apear in the side of the model that i need so how can i change it.
1. You should always construct / design in the correct orientation, so you want get problems with the orientation (preach, preach,... ;-)
2. If you don´t follow rule number 1, use for the rendering "transormation - rotate" and 90 degree with the correct axis and hide the "wrong" view.
greetings
