How can I change the orientation of the second ipt when I`m using combine command?
I`m using derive command for the second solid to call it, but I don`t know how to give a different orientation when it`s called.
On a different face for example.
Thanks beforehand for your attention.
And the second
I prefer to use this way :
- Create 2 separate parts
- Create a new assembly file and insert them into assembly file
And arrange by constrain command. save it.
- Finally create new part and use drive command to insert assembly file
into the part file
USE DRIVE COMMAND AS I SHOW IT ( see picture)
Note : if you change any part's situation in assembly file the last part will update automatically.
HAVE FUN.
Answered with a tutorial: https://grabcad.com/tutorials/how-can-i-change-the-orientation-of-the-second-ipt-when-i-m-using-combine-command--1
