Pinank R
How can I create a rolling wheel in creo parametric??
Question by Pinank R
I want to create a model of a car moving on the road so how to create rolling wheels???
ATHREYA SH
Answered on 14 Jan, 2017 03:55 AM
just draw a plain sketch in any of planes and use torroidal blend and in that 360 deg rotattion
krishna kanth
Answered on 20 Mar, 2017 01:43 PM
Hi
To create a wheel easiest way is “revolve”
To make a tire
Example:
Select the plain and draw a rectangle shape make extrude
Go to “toroidal blend” and select plain take new co-ordinate system from datum
And make a line Take arc make tangent to the line. So final click ”ok “
You can see once more the option of “toroidal blend“ in that choose the option “360 degree blend”
And select the corners of vertical axis or horizontal axis
FINAL TO ROTATE/ROLL YOU WHEEL GO TO ASSEMBLE and make it all the best
thank you..
