How can I do raised text on surface?
I want raised writting on surface. how can I do?
1) select the face on which u want to write the text.
2)click sketch and then click on the text button on the sketch entities tool bar.
3) select the desired curve and the select the font and other entities for the text.
4) then go to features and do use the feature u like.
there will be many options for the text.
if this is not enough see the tutorial.
pls click "it worked "if u like it
Answered with a tutorial: https://grabcad.com/tutorials/how-can-i-do-raised-text-on-surface
