How can I know if a model in solidworks does not overturn with the action of the wind
hello I need your help, I have a simple model with hss profiles 3x3x1 / 4 and the bases of profile C 6x8.2 but I want to know if it is stable and does not tip over with the wind pressure of 60 Pa, help please, I am using solidoworks
Accepted answer
The way to approach this problem is to work out the forces acting on the structure.
The depending on what we want to achieve, that is, get an answer, in that case we would just do the calcs. as these are relatively simple, or if the object is to practice our simulation CFD skills we would use this to set up a simulation. The results of the simulation can be easily checked manually. I have attached a document momments.pdf
0 Other answers
