How Can I Make a Crushed Paper ?
Hi Grabcaders;
here is an intreasting question for all of you.
i wanted to make a crushed paper for some rendering purpose.
can some one help me out???
thanks.
Easy boy... (Handshake)
Have you ever try to put a nail in the wall by using instead of hammer a screwdriver...
I bet you didn't at least you thought that a small rock would be better idea...
So... the answer is... go and find a software like 3d MAX , Rhino, or relative and take your result the next second save as iges or relevant & import to any solidworks Inventor Catia etc.
The right tool for the work... A crushed paper is so random crushed that any solidwork inventor or catia will not help you to do...
However, if you want to draw this in any of the above solidwork inventor or catia is not that difficult as you can use surface modeling...
Here is how it goes...
Two or more 2d drawings in distance the more layers of 2d drawing the most complex and random will become...
1st drawing ---> you start with random profiles or points
2nd drawing -----> just random points these are the peek points of crushed paper
then you can use loft
but this is not the only way I bet if you start with that
you will find at least another 3 ways to do
Another idea ( you see it just comes... like that)
3d drawing ----> connect random points from the above 2d drawings
and build surfaces from the close 3d profiles...
But again it doesn't worth...
Good luck with that though let me know your results...
