Missing feed
how can I make a thin surface out of a closed spline?
By farzane habibollahi on 22 Jun 11:26 3 answers 1309 views 0 comments
I have drawn the base plane of a guitar and I want to use it to make the body
  • Stephen Nyberg
    Stephen Nyberg about 4 years ago
    Select your sketch and then use the extrude feature. There is an option for thin feature. When you select this you can choose how thick you want your solid to be and what side of the line to be on. I can try to put a tutorial together later.
  • Fahad Rafi Butt
    Fahad Rafi Butt about 4 years ago
    you can also use surface extrude>thicken, planer surface>thicken>shell etc lots of ways, Stephan's way is the shortest and easiest!
Add your answer to: "how can I make a thin surface out of a closed spline?"
