how can i measure angle in catia?
hey guys,
how can i measure this angle ? part is in attachment.
hello, if you are in sketching workbench then click on one of the sides of the angle, then click on the 2nd side without clicking anywhere outside. or else you can use measure option, I think there is a separate icon named measure.
can i measure in measure between commands?
Use the Measure tool, as Fakir suggested. It works with sketch or 3D.
Measure between commands? If you're asking "can I measure while in the process of creating a line (or some other command)?", the answer is NO.
