How can i open these files in my catia software.. I am working on V5R17
After Downloading What to do? Cause i tried unzipping it and ten opening.. It unzipps But it does not open...
Comments 2
If you are talking about the files you downloaded from Grabcad, the uploader may be using some other higher versions. For example, m using v5r19. so it's not possible for you to open my files directly in urs. in that case just download the step/ iges format.
Hi Saurabh, I did experience the same issue previously, the best option I suggest you is Upgrade the current version of CATIA V5 R17 to R18!! This should resolve the issue!!
The issue is none of the files created in higher version will not open in the lower version!
Eg: If the model is created using R19, you will not be able to open it in R18, however, model created in R18 should open in R19!
how can i open these files in my catia v5-r20???
