how can i put dimentions in autocad in both metic and fractional inches at the same time?
Add your answer to: "how can i put dimentions in autocad in both metic and fractional inches at the same time?"
units conversion are not the same
right click dimension, go to "Quick properties", if a white window appears, turn on alternate units, apply , ok, then right click dimension again, go to "quick properties" Turn on "ALT enabled. HTH
Thought you knew how to make a Fraction. HERE do this then.
