How can i render textured braid hose?
I am rendering hoses and got this problem.
I used knurled for texture but the problem that I encountered was I cant get the two color combination of a black diamond and white line. How can I get the texture and color at the same time?
You will have to use two different textures, one for the bump map in the surface finish tab (the knurled will be fine) and one with a white line pattern for diffuse in the color/image tab. You will have to sync them in size and rotation in Photoshop or any other paint program before applying them to get the proper results.
